gmc4hire Junior Member Apr 15, 2019 #1 Plan to use washers at the heads of backing plate bolts to take up length of bolts so castle nuts and bolt holes line up properly. Good idea?
B Benson Well-known member Apr 15, 2019 #2 We discussed this a year ago these two links will answer your question. What it amounts to is that there are two versions of the grease seal and you must use the correct bolts and nuts for each type. Be sure to read carefully and follow the links on these two pages. A number of folks have some good info here ... https://www.fordbarn.com/forum/showthread.php?t=241062 https://www.fordbarn.com/forum/showthread.php?t=245141&highlight=backing+plate Berts (www.modelacenter.com) has the new baffles and bolts and washers in Repro. So you can be sure you get correct parts ... gmc4hire said: Plan to use washers at the heads of backing plate bolts to take up length of bolts so castle nuts and bolt holes line up properly. Good idea? Click to expand... Last edited: Apr 15, 2019
Tom Endy Well-known member Apr 15, 2019 #3 Attached article may help. Tom Endy Attachments Rear Backing Plates.pdf Rear Backing Plates.pdf 147.5 KB · Views: 34
gmc4hire Junior Member Apr 15, 2019 #4 Thank you, to all. Ordered new backing plates. If they arrive w/ the raised collars that will work. If not I will use washers @ the bolt heads.
