jwinterstein
Last evening my 29 model A Sport Coupe was running well after I changed the water pump which had a bad front bearing. Today, I left to get gas and about 1/4 mile from the house it began to backfire significantly and lose power and eventually stopped altogether (about a mile down the road). I towed it back and it has adequate fuel which is getting to the carburetor. I pulled #1 plug and turned the engine over and saw a good spark. Points are at 18 and the distributor has the condenser on the upper plate. It will not fire at all at this point. Any ideas?
