Bobant
First off, I'm a new owner. Car sat for 10 years and original owner died so I don't have him as a resource. 1930 car. I replaced the plugs, distributor cap,points, and condenser . Also rebuilt the carb. Car is now idling and running great up to about 30 miles per hour. If I go out on the highway at 40 and above it may or may not backfire when I leave off the gas. It gets ugly but does not stall, straightens out by itself and I continue to run. If I open the GAV valve while running 30 or more it seems to backfire less but I have not eliminated it altogether . When idling, it is about 1/8 open. When running 30 or more I open it about 1 1/2 turns. What exactly is the GAV valve, what does it do, and am I messing with the right thing?
I am at the end of my abilities to do much more and may need to get educated help.
PS. -- timing seems good as I did it by the book and used test light and it seems perfect. I also put an extra washer on gas valve in bowl to lower level of gas in bowl. Like I said , seems to run great at 30 and below.
Any suggestions. Help greatly appreciated.
Sounds like fireworks in Chattanooga.
