Gwill65074
I looked for a vacuum port this morning but doesn't have one. I'll start checking all the electrical connections. Thanks
GAV was the answer?Thank you, it is working.
My monies' on nkaminar, and his lack of fuel flow theory. A while back, I was having the same symptoms, and he suggested a "lean" mixture was the problem. Mine was due to a crap filled gas tank that resulted in a clogged fuel flow filter valve that severely restricted gas getting down to the carb. It would start, backfire and quit.
rkaminar also gave me a wonderful tutorial on the function of the GAV. Priceless!
Good luck with yours.
