California Charlie
Once again, thanks to all those who provided me with some very good and sound advice regarding the clutch release mechanism problem that I'm still involved with resolving.
To begin with, I've finally come down to the decision of taking things apart to get to the Bell Housing interior. I do need to replace the clutch release shaft that is drilled incorrectly and also check on the proper fork positioning.
I was doing my best to avoid making this matter into a bigger project, but after trying to extend the clutch releasing mechnism, and not having that work, I know what I need to do now.
One question I have with getting to the Bell Housing interior to do what I need to do,
I see two versions of dropping the rear end to do what I need to do in getting to the Bell Housing....one where the shackles were removed to separate the spring from the axle. The other version shows the entire spring was left attached to the rearend and the spring was uncoupled from its center mounting.
To remove the spring from the shackle would require a special tool to spread the spring. I do have the special spreader tool, which I used to install the new spring. I would prefer to leave the spring as it is with the shackles intact, but would like to have the expertise of those who are on this site.
So which method would be the preferred way to drop the rear end?
Thanks guys for your input.
