You can, while its running, drizzle MMO down the carb till it smokes out. Let sit a few minutes then put some in the gas and drive a good distance (5-10 miles), repeat if its getting better. If it doesn't get better something else is going on.
I've done this on my truck that has a new rebuilt motor with low miles. Usually in the spring after its been sitting for a few months, I MMO it and it frees up the valves everytime.
My condition is a bit different though. Idle is fine, underload or at higher rpms it will buck and pop.
Worth a try as its fairly simple procedure, wont hurt anything, and cheap to do.
