Jim Huseby
Hi Ernie- Regarding oil, there have been some long threads here on that subject with some very interesting reading. I think you should read them all and do some additional research. I will tell you what I used this time at the risk of for sure catching flak for it. I broke it in with Brad Penn 30 break-in oil, then used O'Rielly's 10-30 with ZDDP, having intended to drive just a few gentle miles before changing to synthetic 5-30 or 10-30 with ZDDP, but didn't get around to it. It had 1306 miles on it when I took the pan off. My thinking is that heat generated at the bearing surface is reduced somewhat by using synthetic, at least if there is any truth to the manufacturers' claims.
