At a minimum, a good can of degreaser applied followed by a trip to the local self-service car wash to spray off the crud. Another option for cutting grease is to use an oven cleaner such as Easy-Off, which has caustic in it. It really does not need to be totally grease free, just remove the debris. Use volumes of air to blow out all of the residual water from the rinse.
