If the Babbitt wear is tapered, either the rod is twisted or the crank has the throws ground off-axis. Fix the problem, not the symptom. In any case, if the engine is well used and has run with the slightly tapered clearance without problem, why would you want to increase that clearance on one side only, shifting load and wear from it's present pattern to a new contact pattern on one thrust side only?
