40 FourDrDlx
Almost coincided with Boeings' 100th anniversary 7/15/16.
I have two noobie questions....
First, I thought all such restorations had a tail number with a prefix X ?
Second, I thought protocol on engine starting sequence was to rotate port~starboard, rather than both on one wing then the other wing?
Coop, Thank you for the detailed explanation! Which brings up another point... I remember some time back the Confederate Air Force was offering rides on a B17 for a fixed "donation" fee. Was that a breach of rules for the Limited status, or is it still OK? (Yes, I know, the CAF had to change it's name.)
Alan.....The "469972" that you see on the vertical stabilizer is what is commonly referred to as the BuNo, or "bureau number" on a US military aircraft. It represents part of the aircraft's serial number. In this case, the "4" in the first place represents the year 1944, the year this particular aircraft's identity and birth certificate came into existence by the powers that be in a Gov Procurement Office. Most aircraft of the WWII era used this numbering system where the year (1944 in this case) was shortened to only the LAST digit (4). This particular aircraft's full serial number is 44-69972 as shown in FAA records. Now, to possibly confuse matters a little more, any PRIVATELY-OWNED aircraft registered and flown in the US is required to have an "N" number. The "N" number on this aircraft is N69972. Many owners request "special" "N" numbers from the FAA, which obviously the FAA accommodated for in this case. This particular aircraft (and many restorations like this one) falls into a category that is different than a "standard category" aircraft that originally would have gone through a lengthy, full "certification" process. These restored military types of aircraft usually fall into an "eXperimental", or "Limited" category. These aircraft still require a placard affixed to each entry stating EXPERIMENTAL or LIMITED status for un-aware mortals that need "legal" warning. Such an aircraft could never be used in a "normal/everyday", airline-like, paying-passenger role. In older times, these EXPERIMENTALS and LIMITEDS had "N" numbers that started with "NX", or "NL". As said above, this aircraft's "N" number is currently registered as N69972. "N" numbers are similar to what we know as a license plate number on a car.......it's a "registration" number. "N" numbers are only required to be AT LEAST 3" in height. And they are only required to be displayed once on each side of the rear portion of the fuselage.
Usual start sequence on most four-engine aircraft is #3, #4, #2 and #1. DD
I had the pleasure to take a ride in FiFi in the mid 80's out of Harlingen TX - at the then Confederate Air facility- It was a memorable experience- particularly remember the engine control station montoring a sea of gauges and crawling thru the fuselage tube to the rear - was like being in an endless MRI machine.The other B-29, "Fifi", will be in Oshkosh for the EAA show, the last week in July.
Coop, I stand corrected. The ac we were operating were in the limited category.
But we flew paying customers all the time. TonyM.
I'm sure it could be in a sharing catagory or donation It takes deep pockets just to fill a B-29 up. FiFi sat idle for a long time just waiting on a couple of engine rebuilds.
