B/W t86 ****** input bearing retainer seal
My 1959 ford T86 B/W ****** has no seal for the input bearing retainer spline shaft that carries the clutch throw out bearing. My old ****** book show some illistrations of having such a seal and others don't show that seal. I certianly do not want 80/90 gear oil to escape onto the clutch friction plate so I am asking where do i get a part number or even did that shaft need a seal??
Some B&W transmissions were set up with seals and some weren't in that era. My early 51 Mercury cars with the 49/E51 overdrive transmissions used no seal on the retainer snout.If it has one then a replacement is available but if it doesn't, I wouldn't worry about it.
