I measured six and the small end width is 1.600 - 1.604 inches, same as the Model A, to my knowledge.
It may be easier to narrow the rods, I have done this in the past.
Did I sell you those Pontiac rods I had? ( I can't remember) If I did why not use them if you don't want to use B rods?
a word of caution, the "B" rods were 1.000 pins, usually when the pistons are made for narrow rods the pins are .927
make sure to check this.
reciprocating weight (piston) increases the load logarithmically so if trying to run some RPMs keep that in mind. the lighter the better, and the con rod bolts are what take all the abuse. there is a reason that ARP gets $50 per rod bolt for the Carrillo rods.
J
[/attach][/attach]
A hacksaw will narrow the rods any amount you need. There is no strength in the outer portion of the rod, so no worries about that. Balance the rods before installing them. Piston weight is important too, lighter is better.
Hey John,
Yup, 1" pins in these Ross. For 4" bore. Modern ring pack.
I hear what you are saying regarding reciprocating weight. I'm in a bad way with these pistons, as they have .680 dome thickness ! .500 over stock thickness !! Maybe wait till I get a head that will run better with carved dome ? Can remove .032 to bring comp height down to even with deck....but that ain't much compared to what's there. Not sure that Ross will have a 'solution' for this situation ? Heck, maybe further ahead to hang these on the wall and get a super light set, eh ?
Ross usually supplies a spec sheet for the set, how much do they weigh?
have to be over 800 grams. also what is comp height? dome height? sounds like someone missed a dimension.
J
Spec sheet says: 'C.H. 1.400'.
Dome height says: 0.500.
Net dome cc's- SPL
Piston weight says: 938 grams.
Note: The way designed, these Ross are same .032 popup (now) as stock . When placed side by side with STOCK model A piston, pins on both sit exactly opposite each other. The RINGS on the Ross are way down the dome compared to stock.
Hm, just realized that the old dude must have been going to use a LONGER rod to bring dome on Ross up.....if it were to be available to carve, eh ?
Or any combination of stroked crank with longer rods.
J
Those pistons could be lightened a whole bunch.
The average 1 inch pins can be lightened considerably also.
It would still be heavier than a lightweight .927 pin.
My guess is you could probably lose 400 grams from the
combo.
HOWEVER, this is going to be expensive unless you can do the work yourself.
It may be cheaper to order a new set of lightweight racing pistons from Ross.
If you are going for really light, a significant amount can be taken off of Carrillo or any H beam rod and still be within safe limits for 6000 rpm.
If this is going to be a really high performance engine you might also consider doing a bob weight balance job at 70% on it. Also consider dry sump oiling. It is good for 30 hp alone.
