Rusty Bolts
The bottoms of both my B pillars are roached out and I thought I'd fab up some pieces to weld onto the bottom. The problem is that I can't get the wood out. The original wood seems to be okay, but it is a bit fragile and I don't want to destroy it.
I removed the two thru bolts that hold the dovetail, and the three thru bolts with nuts just under the latch pocket. I pulled all the nails from the body panel that nail thru the front of the metal pillar and into the wood. There seems to be a liberal coating of tar in the socket but I have ran a putty knife up and down the entire length of the front and rear sides.
Is there something else that I'm not seeing here??? I'm tempted to just cut away the metal on the bottom and try to mig it with the wood in place???
