Ron in Quincy
A few years ago I acquired a almost new B cam; when I set it in V blocks to check the lift I found the following:
All intake lobes had a lift of .321
All exhaust lobes had a lift of .329
A old National Book I have says for the clearances settings of the valves on a 32 "B" engine:
Intake setting: .011 to .013
Exhaust setting: .018 to .021
I know the "B" engine had a high compression head, and was rated at 50 HP.
I used this cam in a rebuilt A engine with a new High Compression Head.
I set the intake valves at .014 and the exhaust valves at .018 . The valves were not noisy and I never had a problem with a burnt valve. The engine ran very strong with good excelaration. I had lightened the flywheel to 39 lbs.
My Question is ? Due to the high compression head of the 32 B did they think the additional heat would cause the exhaust valves to grow ?
Thanks for any thoughts !!!!
Ron
Ron
