B Model Scat Crank
colin1928
B Model Scat Crankshaft Has anyone used 1
I know they use A model conrods
What do they use as rear main seal and thrust lip they looks a little strange in there photos
Thanks Colin
Did contact them said the seal was new style but no idea which 1
As for the thrust lip missing on there crank no real answer
was hoping someone who who had fitted 1 could tell me if they needed to do any modifications or if it fitted straight in
Colin
They use the SBC rear seal. Thrust can be set up for either center or rear main thrust. You tell them what you want when you order it. Try to talk to Tom Lieb when you call them.
I've only fit them to new builds. Blocks were machined with the crank in hand.
SCAT is the name of the company in Long beach that makes crankshafts,rods and many other engine parts, quite a bit of it for General Motors. Tom is a collector of early vehicles out of the teens,real nice guy.
Thanks for the info makes sence to use sbc seal
also told the photos are not The B/C Crank
Cheers Colin
Eubanks and Drake made cast nodular (ductile) iron cranks for A's and I think B's several years ago. I haven't heard anything about Eubanks and Drake since about 2006. Volume 1 issue 2 of Model A Times had a rudimentary story about them.
If I could get my hands on one, I'd take a cast nodular iron crank for a banger any day over a forged! They are plenty strong, many high power big blocks from various OEM makers used them as production parts as they proved both superior and cheaper than forged. The two big advantages: 1) They are stiffer (flex less) than a forging and due to the grain structure they readily dampen shock waves, converting the energy internally into heat. 2) Superior bearing surface oil retention and oil drag, plusses with plain bearings like inserts or cast babbitt. Disadvantage: There is a limit, perhaps 250 hp on an A sized crank. That's well beyond my limit!
If a new one were to be cast with 80+% counterweighting it would certainly be a welcome 'buzz killer' for those nasty I-4 second order harmonics and permit an extremely light flywheel, taking loading off the rear flange.
