its not only the higher compression, but that head breathes better too. The result will please you. I've seen too many used heads that were warped. Its worth it to have the head checked for flatness with a machinists straight edge, or have a machinist skim it slightly to see if it is flat, and if not, have it surfaced. Even a modest warp will cause head gasket leakage.
