I'm doing a ground up restoration on '31 roadster and have opportunity to buy fresh rebuilt Model B engine with transmission bolted on.
You can expect a big shift pattern--I went to '39 gears to get the pattern more reasonable. You may need to use a 31 front timing cover to bolt the model A front mount to. You will need the special rear float-a-motors, or you'll have to fabricate rear mounts. You can expect more power, and especially if the B engine has a counterbalanced crank, smoother running. I also used an A head and water pump. The B head is about 4.6 to 1.
If you are going to use a Model A distributor on the B engine you might install a Model A front timing gear cover and save all the drama of the timing problems if you use the B cover ( B cover starts the timing at 19 BTDC (crankshaft degrees) unlike the A which is 0 Degrees.Would appreciate advice on what I might expect if I were to install Model B engine and transmission in my 1931 rolling chassis. I'm doing a ground up restoration on '31 roadster and have opportunity to buy fresh rebuilt Model B engine with transmission bolted on.
Geo,I've built half a dozen of the trannys ('39' gears in a B case), Can't remember which gear sets for sure. I'm pretty sure the one in my roadster is the same ratios as the stock 32-35 gear sets. Email geohawk@q.com if you have more questions.
