History
Decided to put the B engine in instead of messing with an A engine that needs more than I’m ready to do at the moment. I took the pan off the B engine yesterday and inspected it and it seems much tighter than the A. I have a few questions and I have used the search function and it was helpful but I’m still not sure.
I plan on using my A head so I can use my new leakless water pump as the B water pump looks in need of a rebuild. The head on the B engine now has a C on it, is that significant? Is there any reason why I should not use the A head?
I am going to use the clutch housing off my A so everything will work with the A and it will use the rear engine mounts.
Do I need to put the timing cover off the A on the B engine? If so why?
I understand I need to trim the oil pan on the B to accept the clutch housing.
I plan on using the A distributor .
Will my A starter work on the B flywheel?
Will the B Flywheel fit in the A clutch housing? It had a new clutch pressure plate so I’d like to use that.
I need to change head studs to accept the A water pump/head.
I’d like to seal up the transmission while I’m there, does anyone know exactly what I need there?
There is a fuel pump but no lobe or anything touching the pump arm so I’ll take it off.
If you can think of anything I need to do that I’ve not mentioned I’d appreciate the tip. I wish the forum had stickies to answer redundant question as I know it gets old for you guys answering the same questions over and over. Thanks for any help you can give and all the help youve already given!
