I have read a little about the B distributor and I am using one on my 30 Huckster. What I am not sure of is what initial timing I should set it up on. I have a Nurex Timing timing tab set with the pulley marked on TDC so I can check things with a timing light. Right now I have the initial set at 9.5 degrees but the engine wants to run hotter than it used to. Should I try more initial timing? What is everyone else running who is using the B distributor on their model A?
