S Steve in Tampa Senior Member Apr 16, 2022 #1 Need to find out the stock specs on a balanced B crankshaft mains and rod journals. thanks, steve
B BrianH Senior Member Apr 16, 2022 #2 Mains are 2.0 and rods are 1.875. That is for a standard size crank.
J johnneilson Well-known member Apr 16, 2022 #3 Typically the mains measure 1.9985 and rod journals 1.8735 std. with 80 plus years of rebuilders and grinding operations, all bets are off, you have to verify every journal. J
