john charlton
I know it is said the B carb gives just under 4 BHP extra . This is on a dyno with wide throttle openings the kind of driving us sedentary old geezers would not do . As in a previous post Henry never bored out an inlet manifold to match carb to manifold throat dimensions . The KAYCE carb which is the same as a Zenith 1 was factory fitted to the narrow bore AF inlet manifold this gives a 1/8" step in the inlet tract Ford engineers were quite happy with that the AF car runs just fine . The thinking must be the throttle plate gives more obstruction . Pics to follow so you can see clearly the factory mismatch . This is double the mismatch in the English AA truck application where Henry put a B carb on an A manifold .
John cloudy warm summer evening Suffolk County England .
