B/C crank....
hardtimes
La
Ca
WANTED:
If you have a B/C extra crank in the shed, that you will not use, I'm shopping for one ! I have .010 under.... poured Babbitt B rods and mains, so crank should be able to be cleaned up/turned to accommodate that size. PM and Pics and Price.
Alternative:
I'd buy a rebuilt short block, that you're not going to use instead of building my B block. I'd like a short block that is with larger bore/larger valves, inserted and / or any configuration you have.etc. I know their costly, but if you can use the $ instead of stored engine..let's talk :) !
BTW..I'm 'dealing' with a rebuilder now, so please no builders needed right now, thanks !
I thought I saw a B counterweightd crank on FordBarn y/day or possibly ebay.
Paul in CT
Hey Paul,
Thanks for the heads up, but I've already checked those leads out. Plenty of them out there, just got to get the guys to see my ad. Plus the crank has to be in basically unmolested condition:) !
IMO, there are plenty of good rebuilt short blocks stored/unused also..but got to see my ad....and mabe divesting and/or need the extra dollars now....................
Can do you a new one here, Currently having a 5 bearing one made so 3 would be easier however freight could be expensive, Try Ron in Newhall. Derek
Hey Derek,
NEW one :confused: I'll PM you.
Are you aware Ron's shop burned down, but I'll call him..thanks much:)
Yes on Ron but that was 11 months ago. new one is now done , was there in Aug. I want a B diamond block , no crank needed,So if you find a complete unit . keep the crank & ill take the rest , Have 2 spare sets of rods & caps plus main bearings caps spare, Good luck on a cranks ,must be some out there, Derek
wanted:
If you have a b/c extra crank in the shed, that you will not use, i'm shopping for one ! I have .010 under.... Poured babbitt b rods and mains, so crank should be able to be cleaned up/turned to accommodate that size. Pm and pics and price.
Alternative:
I'd buy a rebuilt short block, that you're not going to use instead of building my b block. I'd like a short block that is with larger bore/larger valves, inserted and / or any configuration you have.etc. I know their costly, but if you can use the $ instead of stored engine..let's talk :) !
Btw..i'm 'dealing' with a rebuilder now, so please no builders needed right now, thanks !
tttt
