Additional info here:
ratios of B and V-8 transmissions:
http://www.vanpeltsales.com/FH_web/flathead_trans-gearratios.htm
Model A ratios are 3.12 1st, 1.85 2nd and of course 1:1 in 3rd.
Note that there are two popular versions of the V8 ratios:
The V8-60 ratios are another animal and I did not examine them.
1. One V8 with almost same same 1st gear (3.11) and a slightly higher 2nd (1.773 vs 1.85 on stock A).
2. Second one with 2.820 first and a 1.604 2nd gear. This
is close to the Mitchell (15% 1st - 15% 2nd version).
The Lincoln-Zephyr gears are
too tall for A model A when used with 3.78 and the .411 also.
Even with a V8 engine, Paul Garrigan told me that he found the taller of the Zephyr gear sets to be too much for his hopped up V8. 296 CU with two 97's, Offy heads. 4. 0 inch Mercury crank and .250 over bored (yes 1/4 inch over bore- 3 7/16ths).
He removed the tall LZ gear set and installed the lower ratio of the two L.Z. gear sets.
3. Mac Van Pelt's book can be found on his website ... VERY good info on building V8 / B transmissions and what gear sets fit what cases and which interchange.
Also explains why the 39 and later synchronizers are better.
Paul's comment when I asked about putting a B or 32 to 38 V8 transmission in the Coupe was: "They are
only slightly better than a Model A transmission and
only IF you double clutch them!"
Also that the side loader (40 to 48 as I remember) gears will fit the top loader cases. Assuming that you have a "double loader", 3 inch top shifter that Pat in Santa Cruz talks about above.
Lots of good stuff!
