Axle shafts
frames
CONCORD
NC
F O U N D ****Not sure what I need. I purchased a Halibrand 201 quickchange center section. I think it is N O S from 1950. The carrier is fitted with side gears to use slip in axles. They may have used 50 Merc or F 1 side gears. 19 tooth splines and about 1.255" O D. Please check if you have some of these axles. THANK YOU. 704 788 8225
