flatheadfan
Guys-
I have a '36 rear wheel that has a pronounced wobble. I have swapped wheels thinking it was a wayward wheel but it appears it is the threaded axle end that is bent. The axle shaft does hold the axle key without a problem and seems to rotate freely by hand without binding. Question: Am I looking at a change in axle shaft? If so. I do have another axle shaft (used) and it also has a slight bend (note pictures).
A lathe would be a good check for run-out but I live in the "sticks" and access to a lathe is virtually impossible.
I suspect the "bends" are the result of improper removal of the drums over the years.
Thanks for the helps.
Tom
Tom
