Matt in Alameda
I may have broken an Axle in my 1935 5 Window Coupe........Who sells axles? What years interchange with 1935? Thank-you,....Matt in Alameda
And if you put in a used axle, make sure it is from the same side as you are replacing..
For the reason that an axle that has been used to being 'torqued' predominately in one direction, might not respond well to being torqued in the opposite direction, as would be the case when swapped from one side to the other.OK, ...just how is he to determine that?
And if he could determine that, what would it matter?
