axle drilling
frank long island
down to the end of my 5 lug conversion I have ranger 9 inch drums to match the 9 inch 4 lug from the 64 ranchero I made a bushing to center the drum on the axel using one of the original studs my thinking is ford used the 4.50 pattern on both 4 and 5 lug so by centering the drum on the hub I should be good to drill has anyone done this:confused: any thoughts thanks I will post pics when done also did a disk conversion using stock 6 cyl spindles along with a duel master and all new suspension parts the springs were the worst:eek:
ok drilled the axle today bearings tomorrow and then reassembly and see if everything fits its now a 64 ranchero with 94 ranger brake parts everything test fitted ok only modification was rounding the hole for the e brake arm pin and changing the brake strut to a ranger one also have to bleed the brakes
back together alignment tomorrow then a test drive seems the old saying is true mother is the necessity of invention the bushing seemed to work :D
