Front hubs/drums and brakes and spindles appear to be 1935, since the drums have fins around them and 32-34 do not... also, there appears to be an aftermarket steering arm/adaptor on the LH spindle; 32-34 have an integral arm. The axle with the "B" part number might be a later replacement for Model A? The 1935 tie rod would have the late-style ends. The steering (Pitman) arm looks to be A as already posted, and the drag link has the early-style ends consistant with A thru 34.
Take the drums off and measure the shoe width. If 1-3/4", they are 1935, which is also the same brakes as 1936 until they were redesigned mid-year.
The shoe surface in the drums will also be 1-3/4 approx.
I would guess that someone had this setup on the front of a Model A???
