Sta Bil now makes a "Marine Formula" for the E-10 which is equivalant to Star Brite's "Star-Tron" which came out a couple of years before Sta-Bil's product.
MMO is totally different and is an upper cylinder lube. I use MMO faithfully in the Model A, and my seasonal engines get either the Star Brite of Sta Bil product in ADDITION to running them dry at end of season. This has helped in all cases save for deteriorated vinyl fuel connections.![]()
Yesterday when I was at the county airport a club member called me and said he was out of gas in his Model A near the airport. I explained to him we didn't have auto gas, only avgas 100LL, which is 100 octane with no alcohol and a small percentage of lead. I have burned 100LL in everything from an antique Curtis 0X-5 to chainsaws with no problem. He agreed that it should be ok as he only had 5 miles to get home. We put in 2 gallons and off he went.
Later that evening he called and told me what happened. After about 3 miles the engine stared heating up and missing, by the time he got home it was running on 2 cylinders with a blown head gasket. He was pulling the head last night so I hope that was the only damage.
My question is do any of you petro chemical engineers have any ideas as to why 100LL would cause this or was it just a coincidence?
Probably like Dodge said, when it ran out of gas it leaned out and the marginal head gasket got a hot spot and began to fail. With the high octane gas in and running, the head gasket began to burn and allow the engine to overheat. This began a progressive problem that blew the head gasket. Not the problem created directly by the AV fuel but by the operator's failure to fill the tank but would have had a failure soon anyway.Thanks for all the input. However I am going to rule out operator error, this guy is very experienced in Model A's as well as T's. I am sure it was just a coincidence. The head gasket was probably going to let go anyhow.
