JJASON Senior Member Oct 15, 2017 #1 Hello I have a new 3 core radiator in my truck,driveing around town,stop and go traffic,what should my coolant temperature be on a temp ,gauge
1 1930-Pickup Well-known member Oct 15, 2017 #2 What is the outside temperature? Are you using a thermostat?
Dollar Bill Well-known member Oct 16, 2017 #5 You should get more accurate responses by providing your location. As others have intimated, outside temperature will affect coolant readings. Where is your temperature sensor located - Block, top of radiator, water inlet/outlet?
Bruce of MN Well-known member Oct 16, 2017 #6 Shoot your water outlet neck with one of these: https://www.amazon.com/HDE-Temperature-Infrared-Thermometer-Laser/dp/B00QYX6F5G
