Vergil
virgil whats the mpg and hp benefit's to adding efi? billy
Probably not a lot over a well tuned engine. A couple of advantages may be the EFI handles the different altitudes better, you are able to input what air fuel ratio you want at different loads and RPM and with a crank trigger setup the ignition timing can be dialed in better (you can input what advance you want at any load and RPM). Is the fuel injection that much better --- No and a lot more work, would I do it again --- yes, it keeps the grey matter working and the challenge is fun. This is actually my third flathead injection, the first one I made the housings from scratch (2X2's) to look like carbs (well favor is a better word) and that system was my introduction to fuel injection and what a learning curve that was. I think the best bang for the bucks and less problems is a four barrel carburetor. But as I mentioned I would do it again , no regrets.
Vergil
