Jack 34pu
I have found a banjo rear out of a late 30's Ford that has the radius rods bolted to the bottom of the brake backing plates and to the closed drive shaft housing. I've been told these are the ones to use for an AV8 project. Will the width of the axles fit under Model A fenders? If not, what banjo rear do you suggest for the AV8 project?
