CT Jack
- City
- Hebron
- State
- CT
- Price
- $100
An automatic advance/retard spark timing device for the Model A. Converts your present distributor with automatic (advance and retard). Eliminates manually controlling timing from the steering column.
This is a Nu-Rex mechanical automatic advance system designed to provide 30 degrees of range on all Model A engines. Your distributor remains the same externally and internally and uses the standard timing procedure for setup. Installation is simple and requires no modifications or special skills. Instructions are included. $100. + shipping
