Kevin in NJ
You know this new anti collision stuff is going to make it real hard to run someone down. There is the person you want to run down and you gun it...
Just as you are about to get satisfaction. You come to a grinding halt.
How depressing...
An auto stop for the A is easy. Just need to put a rod that extends about 20 or 30 feet in front the car that will push against the brake cross shaft. As you touch the car in front the brakes apply. To get a more gentle action you can have a telescoping rod with a spring inside.
See easy solution, no computer needed. Just make sure you are always centered on any motor cycles in front of you.
How depressing...
