old28
I am in the process of rebuilding a pair of Autolite 2100 1.02 venturi carbs for a 6 cylinder dual carb setup. I have taken them apart and done all the normal rebuild stuff. The throttle shaft on one carb has more play than I would like to have and I would like to re-do the throttle shaft bushing.
What is the best way to proceed. Are there kits for the job? I don't have a mill or lathe. Are the shafts 5/16 or 3/8 ?
