Lighter weight, allows for installation of more carbs, looks nice and is easier on your back when you remove it. Cast iron also radiates the heat away better than POLISHED aluminum, I think. "WENOL" does a good job of keeping it shiney. But any good alum. polish will work. If it's polished until it is very smooth with no porosity it will be easier to clean.There is also a special coating made by "ZOOPS" that is suppose to keep alum clean and nice. Here's some helpful info about ZOOPs POLISH: http://www.hotrodders.com/forum/zoop-seal-coating-polished-aluminum-results-30516.html
