...As the sud stiffness increases,
> We are not concerned with stud stiffness, we are using them in tension and thread form shear.
the stress in the block threads increases,
> The stress on the block threads will remain the same as long as the torque value is the same and the thread form is the same.
and fatigue life is adversely effected.
Fatigue life of the BLOCK threads is NOT affected by changing the material the stud is made of. That changes ONLY with torque value, thread form and number of cycles the system goes through.
Why do you need studs intended for high performance engines?
>In a STOCK engine, you don't, unless you get ham fisted with the torque wrench.
You would be amazed at how much damage happens when someone thinks they need to torque the head studs to anything higher than 55ft/lbs "to contain high compression heads"
Because I run high performance engines!
The one that always gets me, mill the head for higher compression and then assemble with two gaskets. Does even more damage.
Resurrecting this thread to ask: has anyone actually purchased ARP kit 151-4002? Is it real? I'm curious what their torque instructions were.
Been running ARP studs, washers and acorn nuts for 3 years. I have the B-F Super head and the torque is 60 pounds
Denis, was 60 lbs ARP’s spec or Larry Brumfield’s?
