Desoto291Hemi
JWL,,,,,Amen .
Tommy
Tommy
When I switched over from stock studs to ARP studs, you can feel the difference on the torque wrench. Hard to explain unless you've done it - but I assure you it is true. The ARP studs tighten in a very firm manner - unlike the stock studs and nuts (even with the correct hardened washers on aluminum heads).
Well using anti seize will change the bolt torque. It's been discussed here. I like anti seize. For the average joe a set of studs used or other will be fine. Watching these kids on media putting turbos and whatever on them. Ya whatever. You need to do more. Not that bolts will save the motor.
Y In fact, measuring 'bolt stretch' really has nothing to do with torque.DD
In the end, you do need to ask yourself, how much is your time worth?
I'm seriously asking and maybe I'm wrong in my view point.
