ModelA29
When a stick was also an automatic.
Chrysler cars in the 1950s relied on Fluid Drive. This wasn't a fully automatic transmission; it utilized a fluid coupling paired with a semi-automatic transmission (often called Gyromatic or Tip-Toe Shift). You operated a clutch to put the car into a gear range (High or Low), but after that, you could drive indefinitely without shifting manually.
Mercedes used a solenoid and electronics with a regular clutch for the Smart car. This thing reminded me of driving an old 36 hp VW.
Automated Manual (2008–2015): The second-generation Smart Fortwo (451 model) features a 5-speed automated manual transmission (MTA). It lacks a clutch pedal, relying instead on an electronically controlled clutch actuator to engage and disengage the clutch.
