Are v8-60 intake and exhaust valves the same?
Blowby
Look the same, but are they different? I have seen listings for two different part numbers and other listings for the same part number for both.
TIA
OK, I've had my introduction to split guide installations. Whew! Maybe a bit easier on the bigger engines where you can get your fingers in there. Anyway just wondering, I probably should have replaced my horse shoe clips, some were a bit distorted. Is that common practice? They are all up in the counterbore and hopefully good to go, but do they ever have a problem with those things letting go? If so what happens, the guide just moves up, spring pressure gone and valve not closing? Nothing catastrophic?
Ford V8-60 intake valves have Ford script, and exhaust valves have Ford script and EX on the head of the valve. Ray
