SofaKing Well-known member Aug 9, 2016 #1 I am wondering if the power valves are functionally interchangeable? One type has a visible spring that sticks up into the float bowl, the other has a small brass stud sticking out the top. Carb is marked 91-99, both valves came in the rebuild kit.
41ford1 Well-known member Aug 9, 2016 #2 The one with the small brass stud is a spark control valve. It is used with the Load-O-Matic distributors.
SofaKing Well-known member Aug 9, 2016 #3 41ford1 said: The one with the small brass stud is a spark control valve. It is used with the Load-O-Matic distributors. Click to expand... Thanks! In the instructions it was referred to only as item "28", a not very useful description. Do you have a preferred vendor?
scicala Well-known member Aug 10, 2016 #4 You're 91-99 carb does not use the spark valve. That model carb didn't use one until 1954 (first Y-Block V8). Sal
