mike657894
I am thinking about switching to 16s. I dont want to pay a ton. I see singles pop up on my craigslist occasionally for 20-50$. are they all the same 16x4 or are some different or wider?
I am thinking about switching to 16s...
Most are 16 x 4 but I have seen other sizes. Make sure they are the correct Ford bolt pattern. There are also Kelsey Hayes bent spoke wire wheels, again most are 16 x 4, but I have seen wider ones advertised. if you make sure they are original 1935 Ford write wheels, 16 x 4, with the Ford bolt pattern, you should be OK.
ronn: "I personally like the look of the 18" 1932 wheels-beefier wo going overboard."
While not as 'chic' with the 'in' crowd (and for a number of other reasons, i.e. commonly available, wide variety, etc.) I too prefer the 18" wheel of the 1932 Ford, along with the hubcap from the 1932 Ford Model B (which is different from the later years, and says FORD, rather than V-8) . My set are the bent-spoke Kelsey-Hayes, for a little bit of panache.
Doug,
I dont care what they say about you- you have good taste!
16's are so common that many folks think they came new, that way.
Bill Sixteen
