Ardun Heads
And here is what the original/real brochure really looked like . . . in true 'Hotrod Colors' - black and red baby! I am fortunate enough to have an original document - something about anything related to Ardun just seems to capture my fancy. I don't even remember where I found it . . .
Enjoy!
B&S
And here is something else fun (at least I think so). It is an original lid from an Ardun shipping crate.
I wish I had the whole crate, all I have is the lid . . . but it is something kind of special and cool to me (I guess I'm a bit nuts hugh???):
Having never seeing an actual disassembled unit or full schematic I'm curious. Seems the conversion had to use the original valve openings bushed as valve pushrod guides obviously using the same cam pushing on the conversion valve pushrods to operate rockers on the Ardun heads operating the conversion overhead valves opening into the hemi-head?
Yes except the valve holes are not bushed. Often, the valve holes have to be ground to allow for pushrods clearance. The pushrods are held in place by the special Ardun lifters and rocker arms.
Ronnieroadster, do you know how long spark plugs should last on a normally aspired ARDUN where the plugs holes have been modified to place the spark plugs at the dome rather than being recessed?
From my experience spark plugs will last a long time. Now that I use the longer reach plugs I find there's no indication of fouling. The ignition system I used for the old tunnel fire and now the long reach plugs is a simple Pertronix conversion. For the street and setting the 225 MPH ARDUN record at Bonneville this year the Pertronix works perfectly.
Ronnieroadster
Thx, , informative & interesting. I'd love to get the new Ardun conversion kit for my '35 with an 8BA but @$14K too rich for my blood. But very cool
Consider that just a start! By the time you get all the other things you need (just parts) - even for a naturally aspirated engine, then another $5 - 7K.
Now think about a cool 'Big SCoT' repop blower, aluminum oil pan, special water pumps . . . whups, there goes another $15K.
But hey . . . if they were cheap, easy to build and plentiful . . . everybody would have one! :)
B&S
