Pooch, you can not arc the shoe itself. You cant bend the shoe, to put shims in I would think would leave voids between where the shims are and where there is no shim next to it between the shoe and lining. Unless you shim the whole shoe, you wont have an accurate arc. While the feeler gauge may not fit between the lining and drum, you may be able to slip that feeler gauge in behind the shoe and lining, causing the lining to not be in full contact with the drum anyway. Shims are not right in my opinion. You may be using an original drum but you have not restored it. That would have been bringing back to original. It has been cut on, so now it is an altered part that would probably not be safe at this point, no matter what bands you weld on. They will still be too thin and not dissipate the heat.Some parts wear out. Sounds like for safety's sake, (yours, your passengers, and others on the road) you may want to buck up and pay for those new drums, if you are going to drive the car. JMO
