AR/early 1928 brake part question
old ugly
i am looking for the correct name for the dogbone shaped center equalizer/connector that is between the two cross shafts. the name may help my search.
im going to try find a better one for my shutter buggy.
thank you
OU
you also want to look at the part that the dog bone slides in ,that actually moves the dogbone,,the two I have are both worn.
I have just done a 3 week job on the brakes on an early A brake system, One huge amount of work to get it to work properly, but its now really nice,
started at the brake pedal shaft, and worked from there.
3 days solid work on the lathe making shafts and pins etc, you can buy some parts so they need reclaiming.
Lawrie
let me know if you want some pics
Law
thanks guys.
every thing else checks out nice except the center ball on that dogbone has a slight flat spot on one side. i could build it up and turn it back to round in the lathe but a new one is cheap.
thanks for the help
OU
