pooch
I have read that .070 is the limit.
To get around the outer lip , I placed a 1/2 inch drill on outer drum and measured the total and subtracted the drill size.
Is this the best way to measure it?
If .070 is the limit, and the brakes are 60/40 rear/front, can the front have slightly more wear?
What is the end result of a too thin brake drum?
Does it break off at the flange and that wheel just continues turning with the broken band clamped stationary by the shoes, or does it shatter and seize the brakes up?
(BTW,After dismantling 4 brakes, I am over removing split pins (cotter pins to youse)..I might buy a box of internal star washers!
