More stuff:
This is from Rumbleseats files. If you haven't come accross him, he is a wealth of info on these fine fords.
He suggests a fuel pressure regulator, never set higher than 2 1/2 psi, because 3 1/2 psi overcomes the needle valve.
Anyhow, read it your self.
FUEL PUMP PRESSURE: Ford and Stromberg carbs were engineered to operate at a
maximum of 2½ psi fuel pressure which was pretty typical of carb pressure in the
thirties. Exceeding this pressure can overload the needle/float system (hold the
needle off it’s seat) and flood a carb. This results in gas running down the
carbs and onto the engine and is probably where the Strombergs partly got their
reputation for being burners. The Ford carbs will also suffer from excessive
pressure, but are not as sensitive as Strombergs due to better float leverage
against the needle and seat. This is the result of Ford’s better float pivot
design. When the float is set too high, or if the pressure exceeds 2½ psi, or
the vehicle is driven off-road, the air horn to main body gasket on both brands
of carbs will become saturated with gas. Raw gas and gas vapors will waterfall
down the front of the carbs. Notice the proximity of the front of the carb to
the generator brushes arcing on the commutator? Picture your engine with hot gas
on the front of the carbs and the close proximity of the arcing generator. Scary
isn’t it? Don’t chance it..... limit the fuel pressure by installing an
adjustable fuel pressure regulator and setting it to not more than 2½ psi. I
prefer the Holley regulator. Note the carburetor designed pressure is less than
the 3½ psi Ford specifies for their mechanical fuel pump. Strange Ford STROMBERG NEEDLE/SEAT ASSEMBLIES: These were originally a steel needle and a
brass seat which made them susceptible to the needle being held off it’s seat by
grit and dirt… which resulted in flooding which lead to fires. These all metal
needle and seat assemblies are sensitive to pressures in excess of 2½ psi. Ken
Ct. of the Ford Barn recommends and uses only metallic needle and seat
assemblies.
With the advent of the soft tipped needle (Vitom), the sensitivity to dirt and
fuel pressure was reduced and flooding decreased considerably. I use only these.
Since the sixties several different designs of needle and seat assemblies have
been manufactured. Some are not affected by grit and dirt and many will tolerate
higher fuel pressure. I’ve tried many of them, but end up going back to the
Vitom tipped needles in my Strombergs. I’ve not had a single sticking needle in
the past 135,000 miles so why change?
He also mentioned in his article, about the power valve leaking. Just another thing to check.
assemblies.
