Hi all.
Do any you guys know if there is a way to test a condenser using a good old fashioned analogue multi-meter. I sometimes have cause to make capacitance readings at work, using an analogue ohms meter to estimate the length of underground comms cables. I know the theory on capacitors, but not so much about the practicalities of testing an old ford condenser. When I connect the leads of my meter to the condenser (set to read kilo-ohms), I get a reading of 70 to 100k-ohms. I would have thought it should read much higher than this (say in the 10's of mega-ohms for example). When the leads are reversed, there is a mild "capacitance kick", though it doesn't exactly throw the needle off the scale either. Haven't tried this last test yet, but I seem to remember from training school that a capacitor should be able to be charged with a battery, and should then hold that charge for quite a time, if the capacitor is good. If there is leakage within the unit, then the voltage will drop away fairly quickly.
Anyone know if this theory fits with an old ford condenser, or is it time to stop being tight and just buy a new condenser?
