Scott H
I put the engine and trans on my chassis today but I'm not pleased with the way the motor mount assembly goes together.
I've got the washer registered into the hole in the frame, then the rubber biscuit on top of the washer with the pointed end up.
Problem is the umbrella end that sits down onto the washer doesn't go inside the cup of the washer. That causes the mount to not fit together and I've barely got any threads coming up thru the water pump ear.
Anybody else run into this and have any tricks to remedy it?
