Oh yeah... be certain the two points on the clips are next to each other. In other words, not crossed.
Also, once you start them in the hole, do your best to pull them from the opposite side with a small plier.
A little grease on each clip helps too.
As the paint is new, be certain you take a small file to each hole and remove any built up layers of paint.
